Durvelle27
I'm looking at getting my first car and was wondering what's some good places to look ? I have about $1,500 right now.
$1500 total or $1500 to put down?
Craigslist. Take a car savvy friend with to inspect the car for you. In your price range don't even worry about car models. Find the car that has been taken care of the best. Stay away from teenager owned cars or sports cars.
Because any "sports car" that only costs $1500 is a worn out money pit.
like a 1997 Mitsubishi Eclipse or Pontiac Grand Am
http://en.m.wikipedia.org/wiki/Geo_Prizm#section_3
That's going to be your best bet if you can find a well maintained one. What city / state are you in?
@ 1500 bucks, his best bet is to just look to see what is available and evaluate on a case by case basis. No advise here is going to change what is available to him, nor how well each car was cared for.
Make sure whatever you buy that the timing belt has been done and the brakes, suspension and everything else is in check. If not, be ready to pony up another $1,000 or so very soon. Best bet is to have a good mechanic give the car a once over before you buy it. And remember, an old Acura, Lexus or other 'luxury' car that cheap is going to be costly to fix. Basic parts are a lot more expensive than other standard cars. If I were you, I'd look into getting a Crown Vic that was a former police car or something. At least then you know the oil was changed on schedule. Having the paperwork for the used car is critical.
$1,500 will get you a very high mileage beater with wrecked interior and loads of problems about to happen. Save your money for a while longer, get a job and ride your bike until you have at least $4,500 to spend. Then you can actually get a decent ride.
