Obviously not since windows does not recognize the drive.😉 What is the drive installed as? Primary slave, Secondary master, secondary slave? What other IDE components are installed and at what configuration?Originally posted by: rudeguy5757
I cant...for some reason my floppy disk took a crap on me, can windows do that for me?
Originally posted by: 3L33T32003
First, you have to make sure your bios sees it.
Make sure the jumper is set properly.
And you have to format it before you can boot to winders and try to see it...
Originally posted by: dolph
have you tried shining a flashlight on it? flares help too, or sometimes a magnifying glass. my computer has poor vision too, and it's hard for it to find devices sometimes.
Originally posted by: Slasher2k
Im going to assume you have windows xp and you are logged on as administrator.
First, go into Control panel, then adminstrative tools.
Then Computer Management. Goto Storage, then Disc management.
Click on your disk id number at the bottom, right click then partition, or create partition or something. Make it the maximum size, and let it format it automatically after creating the partition.
This will work even if you can't see the drive number in Windows Explorer as long as the bios sets it up. If it doesn't there, then you will need to change bios settings.
Make sure you aren't doing this to your system drive or another drive, make sure its unpartitioned space, or unformatted space.
