IslandStylin
I have an Elite 430 case and a Z68-UD3H-b3 mobo with an after marker hyper 212 plus on top
Here are the problems....
1st) The back bracket for the aftermarket cooler comes in contact with the case as you can see in the picture. Will this be a problem? (Don't want to start it up until I am re-assured it won't short my mobo.
2nd) The screws that are used to screw in the mobo to the case are messed up. I screw them in like a normal screw and they seem to be stuck in an ever circulating pattern. So they aren't flush with the board. They definitely are keeping the board in place but at the bottom they are not all the way in... Will this also cause me a problem with grounding issues? I know that I am totally screwed if the board doesn't work in the case because i have NO WAY of getting the screws loose. very little force was used when screwing the screws in....They just didn't want to go to their home....
