BassBomb
07 Accord EX-L
My ground cable on the battery is a little loose even though its tightened all the way down.
It takes a little force to move it up but it can rotate about the terminal.
Any tips to tighten this down?
EDIT: Reason I ask is the cable came loose the other day and car would not start. So I moved it back in place and everything was fine again. Lost my presets and had to input navigation code because of this.
I have a picture at home that I can add later
