I have a 97 ford expedition that is making a rubbing noise coming from the front left. But it stops when i make a left hand turn. i replaced the left hub and it is still doing it. could a CV axle be going bad?
Might be a rock or something stuck in the brakes. i had a grinding noise from my front right wheel which would go away on left turns. I did a vigorous "slalom" at slow speeds and it hasn't come back since.
