- Sep 28, 2015
- 2
- 0
- 0
Hi All
I have been experiencing a grey screen problem in my PC for a while. It is not a regular blue screen problem with error codes. It is a grey screen with no writings and I have to reset my PC when I have this. It generally happens when I surf on the net or when I do some petty work on the desktop which doesn't push the CPU at all. No problem occurs while playing games. My PC is pretty old....
P45 Asus P5Q Mobo
Intel E8500 @4.00 Ghz CPU
4 GB DDR2 Ram 1066 Mhz
Ati XFX 6950 1 GB VGA
GlacialPower GP-AL650 650 Watt PSU
Enermax Chakra midtower case (120 mm x 2 fan + 250 mm case side fan)
I tested my hardwares....
- Rams completes Memtest 86+ test without a problem
- VGA completes 3DMark11 test and gets a good score comparing its capacity (4653 point)
- I ran Prime 95 test for 1 hoıur and Orthos test for 2 hours without a problem so CPU seems OK.
- My PSU is pretty good
http://www.bjorn3d.com/2008/09/glacialpower-gp-al650-650-watt-psu/
I formatted and reloaded my operating system Win 7 but the problem wasn't solved.
What might be the problem and what should I do to get rid of it.
Thanks
P45 Asus P5Q Mobo
Thanks
