Graphics Problem?
Quoch
Hi everyone, I was wondering if any of you can help me here. I have recently been having problems with this particular product from your company. It was working fine for a few hours, but after that, I experienced problems because I am unable to receive any signal to my monitor since then.
Everything else works fine even the fan on the graphics card was running but the AGP card signal to the monitor is not functioning. I have also switched monitors and graphics card to try and identify the problem and they were working perfectly fine, it?s when I connect the monitors (3) to this graphics card that there is no signal or works.
Any help would be appreciated thanks.
System Configuration
Intel Pentium III 1GHz 133FSB FCPGA-2
Gigabyte GA-60XT Main board
Crucial 128MB PC133 SD-RAM
Creative SoundBlaster Live Player 5.1
3COM 3C905B-TX Network Card
Seagate Barracuda ATA/66 7200 20GB
Samsung 6X DVD ROM Drive
300ATX PSU
ATX Case
Windows XP Professional
Hercules 3D Prophet 4500 TV-Out 64MB RAM ? Drivers 3DPK-XP-9031
First: Does the computer boot, but just not display a signal, or does the machine fail to boot now? If it's the latter the card is likely not seated properly in the slot. Try taking out the card, reseating it, making sure it's completely pressed in and screwed in tightly. Just making sure: You have tried 3 different monitors, or are you hooking 3 monitors up to the card in some other way?
My computer does boot up and all hardware responds except for the agp card, e.g. hard disk light, main boards ram and power led lights, drives, etc.
I have tried all possible ways of reseating the graphics card as much as possible but still not getting anywhere.
I tired hooking up 3 monitors one at a time to the apg card but monitors keep on saying "no signal input", but when I tried them on my geforce 2mx they work fine.
about all I can say is that the fan on the agp card is always running so I guess its getting power but I don't know about the card on a whole.
thanks for your reply, is there anything else you could suggest?
quoc
