Matthias99
- Oct 7, 2003
- 8,808
- 0
- 0
Originally posted by: xtknight
My 6-bit TN did have quite washed out and tinted colors compared to vibrancy of my eMachines CRT. However, this VP930b (8-bit VA) will match the CRT or beat it at calibrated settings. The CRT didn't look perfect either. It had too much of a red-yellow bias to the image. My VP930b just looked natural. I think the problem is so many people have made images with that red-yellowish bias in mind, or something like that.
Oh, man. Don't even get me started on "red push".
MOST computer monitors are pretty neutrally balanced (or even slightly blue). However, many that are specced as "TV"s (or cheap ones that want to look better in crappy store lighting) add extra red to the video feed because it makes the images look warmer. If you look at two screens side-by-side noncritically (especially under crappy fluorescent lighting), most people will naturally like the one that has more red added to the signal -- but it destroys the color fidelity and balance. If you're trying to do print work, or you want to see images the way the person who created them intended them to look, you're SOL on a display that does this.
Of course, there are people who willingly use NVIDIA's "Digital Vibrance" feature, which does much the same thing (except it cranks ALL the saturation up, not just red). I'm not sure what's wrong with these people.
Originally posted by: Compellor
LCDs usually need to be calibrated properly since they never look that good right out of the box. The brightness is usually set too high, and the color and gamma settings need to be tweaked to get a good image.
It's always a good idea to get an LCD that has a high contrast ratio like 800:1 or better. The lower the CR the more washed out it will look. Also look for an 8bit panel since the color is much better on them. Don't go with the cheaper $300 LCDs if you care about PQ.
That's very true. My VP930b needed a ton of adjustment (DeltaE 5.2 default!). Other monitors like the Samsung 970P (DeltaE 2.7 default!) are very good at default according to BeHardware. In order to make my VP930b not washed out, I had to use the ICC profile on the monitor CD. After I did though, everything looked great. Then I changed my Windows gamma to the 2.20 this monitor specified, and voila. I never thought I'd remove that wash-out, but it's amazing how much a gamma profile can do.
My VP930b also needed quite a bit of tweaking to look good. The profiles and calibration software on the included CD made a HUGE difference. It also looked a bit washed out at first, and just tweaking brightness/contrast didn't seem to help all that much. Adjusting the color profiles fixed it.
With a good, 8-bit LCD, you should be able to make it look comparable to all but the VERY best CRTs in terms of color (maybe not in terms of black level, but color fidelity should be fine). If you read THG'd LCD reviews, they use a LaCie calibrator to set up their monitors, and they have had no problems getting most of the ones reviewed in the last year or two to professional-quality color calibration.
