Graphics cooling
3fps
Hi
Anyone got experience with there components working together? I'm somewhat worried how they will fit together, and stfw gives nearly nothing on the topic.
XFX PCI-E 6600GT and Zalman vf700
on a
Asus A8N SLI DELUXE
with a
Zalman ZM-NB47J
HardWarrior
4,400
23
Do you mean you're wondering if the cooler you selected will fit your video card? It SHOULD state clearly in the description of the unit whether it's compatible. If your worried that there won't be enough room between two video cards you're going to need to find a low-profile unit that works for you.
