graphics card water cooling
Sylvanas
im new to water cooling but it seems to be the way of the future, so im looking for a graphics card water cooling kit (with all the necessary stuff included) or if you can reccommend all the best bits and peices. im looking for the best out there to cool my radeon 9600pro. provide links also plz :thumbsup:
Not sure if it's the best, but I have been using the swiftec block for awhile, and like it alot. I chill my water to 48f, send the water to my Swiftech cpu block, then Gpu block, then to my Northbridge block,(swiftech also), and my gpu reports a 15c idle, and 20c under load. Thats on a Gainward fx5900 at 477/1000. www.swiftnets.com
lol
Google search for:
Swiftech
Danger Den
DTek
Pro Cooling (For DIY Blocks)
I also run the Swifty blocks on my North and GPU.. Very easy to install and work
quite well... Another thing to take into account is the weight and size of GPU block.
Some are quite heavy and large which will make the 1st PCI slot useless. Though most
don't use it beacuse of the shared IRQ with the AGP slot it is good to know..
Originally posted by: DerwenArtos12
I would have to say the best is the danger den maze 4 with 80w pelt thats available at frozencpu.com.
Unneeded expense, hastle and danger incorporating a pelt for negligable real-world gains.
but, he said best, not most realistic. and a pelt lowers temp therefore given best theoretical performance.
danger den maze 4 seems to be the way to go then. what about other supplies like a resevoirs? etc. where would i get these bits....
