Graphics Card Upgrade Help
albingo
12
I currently have this 2GB GTX 670 and I'm thinking of getting another one in SLI, but I have a few questions. I'll only be using 1080p.
1. Is it worth it to get another 670 as opposed to another single card?
2. I currently have this 620W psu, will I need a new one for 670 in SLI?
3. I can buy any 2GB 670, correct?
Current Specs:
i5 3570k @ 4.2Ghz
Overclocked 2GB GTX 670
8GB RAM
Termie
7,949
48
www.techbuyersguru.com
GTX 670 SLI is quite powerful at 1080p, where the 2GB of VRAM won't cause issues in any current game. And you can use any 670 2GB model.
Your PSU isn't ideal for it, though. First, you don't have enough PCIe cables, so you'll need to run adapters, and second, with 48A on the 12V rail, it's closer to a lower-end 600W unit. Your setup with dual 670s would draw about 450W, so it's within the limits of the PSU, but you'll be driving it at least 75% capacity whenever you game, meaning it will run hot and loud, most likely.
albingo
12
Any PSU you recommend? Preferably one that's not too expensive.
Termie
7,949
48
Well, to get four PCIe cables, it can't be too cheap. One of the least expensive options is the Corsair CX750. It's not a whole lot higher-quality than your PSU, but it's a least as good and has power to spare.
nwo
2,308
Each card only draws about 200W, more or less, depending on OC. All you would have to do is spend a few bucks on some PSU adapters. Something like this will do.
48A is nearly 580W on the 12v rail... I don't think that is considered low end for a 600W PSU. It's about average I'd say.
If you are not overclocking anything then your PSU will be sufficient. If you are planning to overclock both graphics cards as well as the CPU, then you would definitely be coming awfully close to or potentially exceeding 100% of the PSU capacity in which case you would have to upgrade to a 700W+ PSU.
My advice is to stick with the PSU you have now, run both cards at stock and keep your CPU OCed. If you are adding another GPU to the rig, I see no reason to overclock them both out of the gates. Save your money for a higher quality PSU down the line when you need the extra power instead of trying to squeeze in a budget PSU.
albingo
12
Thanks for everyone's help so far, but now I have a different question.
I recently installed the Star Citizen Hangar module and put the settings on very high (max) and at 1920x1080. I realize that this is nowhere close to the finished product, so there will probably be improvements, but I'm not sure if a 2GB card will be enough, one ship in a hangar was using 2015MB Vram with around 35fps. Games like Skyrim (with mods) use pretty much all of my Vram and BF4 is using around 1900MB.
So, should I still get a second 2GB 670 card? Or should I go for a 770+ 4GB card?
nwo
2,308
If you have the option of selling the 670 and adding a few bucks for a 4GB GTX 770, I would definitely go that route. A single card is often better for gaming anyway since not all games scale with mutliple GPUs equally.
At current prices, you probably won't have to add more than $50 for a GTX 770 if you can find a buyer for your GTX 670.
albingo
12
Alright, I might do that. Also, is there a significant difference between the GTX 670 and 780? Besides going from 2GB to 4GB? If not should I save a little more and get a 3GB 780? Assuming a 670 goes for about $200.
DI3S3L
Hi All!
I'm new on this forum, and I want a little help. I'm sorry for my language, but I'm not a perfect english :)
I want to upgrade my rig with a new graphics card. Currently, I have a Intel Core i5 760 CPU (OCed to 3,5GHz), 8GB of RAM, Gigabyte H55M-UD2H mobo and a Gigabyte HD5770 video card, 570W Gigabyte PSU.
So, I want to upgrade to HD7850 or HD7870, but i don't know what is the better choice. I playing in 1440x900 resolution, and I don't want to upgrade my display to FullHD.
What is the ideal choice for my configuration? The OCed i5 760 is enough for 7850 or 7870?
Techhog
2,834
Hi All!
Yep. That won't bottleneck those cards in most games. Maybe a bit since that resolution is a bit low, but it's still more than good enough.
nwo
2,308
Hi All!
Your overclocked CPU definitely will not bottleneck either one of the two cards.
If you give us the prices of the 7850s and 7870s you are looking at, then we would be able to tell you which would be a better choice. If there is a big price difference (more than $30) I'd say you would be better off going with a 7850 as long as it is the 2GB version because the performance difference is really small.
Leyawiin
3,204
52
I have that exact card paired with a much less capable CPU (Phenom II @ 3.9 Ghz) and it doesn't really bog down in any game I play @1920x1200. Can't really understand the need for more power @1080p.
DI3S3L
Thanks for the reply for everyone! :)
The price difference of the 7850 and 7870 is really small currently. I've better choice the Radeon HD7870.
