- Nov 2, 2012
- 3
- 0
- 0
Hello people, I have an issue and your help would be much appreciated. I have an old machine, the specifications of which I have specified below:
AMD Athlon 64 3500+ running at 2.2 GHz (single-core)
MSI K8N Neo4 Platinum motherboard (nforce4 chipset)
500 W Good Quality PSU with more than 26 A (not sure of the exact amperage) on the +12V rail
2 GB DDR400 RAM
Windows XP Professional (SP3)
500 GB + 160 GB Seagate Hard drive
LG DVD Burner and so on
The issue is that I was using XFX 8800GT Alpha Dog Edition (512 MB) graphics card on the system. Now that it is dead, I am on the look out for a new graphics card.
I have researched a bit on the Internet and found that the equivalent of my previous graphics card is this one:
XFX Radeon HD 6670 (GDDR5) with 1 GB VRAM
I also see that many people on the Internet are recommending Radeon HD 7750. But, when I check the requirements, I see that Windows XP is not one of the supported Operating Systems.
Now this has put me in a bit of a dilemma. Will the above mentioned graphics card (Radeon HD 6670) work with my system?
I understand that it doesnt require auxiliary PCIe power connector, but I am more concerned if my single-core CPU will support it or not.
Also, does it really matter if I use a non-Nvidia graphics card in my system?
Another thing of importance is that I will be mostly playing old games (2007 and earlier). I have so far only used Nvidia cards and I am worried if ATI or AMD cards will have compatibility issues with old PC games.
I am also open to graphics card suggestions by you people, but please note that I am on a single-core machine where I am bottlenecked by the CPU.
Thank you for your help and suggestions in advance.
2 GB DDR400 RAM
