Graphics Card or Monitor Problem?
knightwalk
My system specs:
OS: WinXP with service pack 1
Graphics Card: GeForce 5900XT with 66.17 drivers
DirectX version: 9.0c
Monitor: A not-so-popular-brand monitor (CTX X90)
After getting my new 19" monitor, I replaced my old 14" monitor with the new one, then started my PC. The new monitor was working fine. Then when I tried to access the Nvidia properites/control panel, the system hanged and restarted by itself. The same thing happened when I tried to run any applications which requires the graphics card processing (e.g., watching movies, playing games). Tried to run the DXDIAG directx diagnostic tool, but it restarted also after running that.
I tried to uninstall the Nvidia drivers, and reinstalled it with different versions, but still it cannot work. Will hang when I run anything which requires graphics processing.
Any comments about this problem? Haven't tried reformatting/system restore though...
I don't think the new 19" monitor has anything to do with this I suppose. Coz when I switched back to my 14" monitor, and reinstalled the drivers, the same problem occurs. Most probably the graphic card has problems? (Its been working fine previously also. Been playing games with it recently). Or is it the problem with the drivers or directX?
Thanks in advanced.
AnonymouseUser
9,943
107
My first thought is that the old monitor isn't plug 'n play, while the new monitor is, and when you installed the new monitor it was automatically detected and drivers installed. Problem might be that the old monitor drivers haven't been uninstalled and are conflicting with the new drivers. I suggest booting into safe mode with the old monitor connected, and uninstall it (here is a simple guide I found with a quick google search since I haven't had to do this and wasn't sure of the procedures), power down, swap monitors, and power up.
knightwalk
Both monitors are plug 'n play, which doesn't require any drivers at all.
But probably WinXP has automatically installed some kind of driver for my old monitor last time, so I will try to uninstall that one. Thanks for the link.
