Graphics card help
i3rYs0n
1,525
Just want to know if 480 x 600 was the smallest screen res. If not i got a computer that is hooked up to an old tv so 480 x 600 is kinda bad, i need to know how to make the screen res smaller cuz the lowest setting it lets me have is 480 x 600.
Hope you understand this,
LaSt
Tsaico
2,669
i think that is the smallest resolution you can have, and not to mention, if you are using a tv as a monitor, you are bound by its resolution limitations.
CubicZirconia
5,193
Actually, you can go quite smaller than that. You can go down to 400x200 and 320x240, probably even lower if you really want to.
