Question Graphic card for running 3d applications
philoman
I want to install a Graphic Card for running 3d applications ONLY such as 3d max.
My System configuration :
Desktop PC
Windows 7 ultimate
Processor intel (R) core E7300 2.66GHz
2GB ram
SMBios version 2.5
Before going in for a buy, I would welcome any suggestion in this regard.
I would simply consult Autodesk's certified list for 3ds max... mostly likely a low to mid range NVIDIA Quadro or AMD Firepro card up to 4GB
Hardware CPU64-bit Intel® or AMD® multi-core processor with SSE4.2 instruction set
Graphics HardwareRefer to 3ds Max Certified Hardware for a detailed list of recommended systems and graphics cards
RAM4 GB of RAM minimum (8 GB or more recommended)
Disk Space6 GB of free disk space for installPointing DeviceThree-button mouse
Look at the 2019 graphics cards recommended and it is Nvidia Quadro P2000 series and above for current models, AMD Firepro and Radeon Pro WX. Talking serious money. You get to buy some gaming graphics card too!
Looking back to your original post, you have a old PC with only 2GB RAM, I looked it up and this is the review shown below:
Core 2 Duo E7300 2.66GHz compatibility review
Overall, the Intel Core 2 Duo E7300 2.66GHz has decent performance. Its 2 cores clocked at 2.66 GHz provide competent processing speeds but allow few processes to be run simultaneously.
The CPU is now over 10 years old, which means it is extremely out of date and is based on very aged technologies. This processor will be dwarfed in performance by its modern counterparts, and will likely have very little support from Intel.
Created with lithographic technology sized at 45 nanometers, the Core 2 Duo E7300 2.66GHz is not efficient at all by modern standards, and with a Thermal Design Power of 65W the amount of power necessary to run it does not make up for the inefficiency of its physical structure.”
http://www.pc-specs.com/cpu/Intel/Core_2_Duo/Core_2_Duo_E7300_2.66GHz/225
Core 2 was release in 2006-2011. I think your CPU was release August 2008.
https://en.m.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors
Time to get a new PC! Get an i5 or above. Stay away from the entry level i3 PCs. Talking 7 or 8th generation Intel CPU. 9th generation just got release! Shoot for 8GB RAM and 256 GB SSD or larger NvMe M.2.
https://en.m.wikipedia.org/wiki/Comparison_of_Intel_processors
Probably have to upgrade your AutoDesk program.
Otherwise, you have find out the highest Quadro graphic card that will run on your Core 2 and upgrade your RAM too! Both hardware components should be pennies on the dollar! After all, it for a 10+ PC. I try eBay!
