- Jan 15, 2000
- 7,052
- 0
- 0
Initially when i would turn the FRAME LIMITER option off, i would get extremely jerky movement (high fps followed by low fps) and it was unplayable. I recently downloaded FRAPS to check my ingame FPS. To my surprise when i was running fraps in the background I could actually play with frame limiter off. It was smooth as hell, and i was hittin close to 100 fps at 1280X1024 32 bit color in certain areas. I suggest runnin FRAPS in the background and see if that helps at all. On a side note, anyone figure out how to get FRAPS not to display the framerate in the top corner?
