Gran Turismo 4 Help (Suspensions,Braking)
clarkey01
3,419
Hi
Can someone list me there specs for their ideal suspension settings, brakes settings, and downforce in GT4 ? I am trying to create the bend handling car which will take corners the best, cheers
:beer:
BCYL
7,803
There is no 1 setting, each car will vary... you just have to repeatedly test and tune to get the best setup...
clarkey01
3,419
Ok, for Viper GTS, I have the front brakes on 10, the back brakes on 24. I have the ride height very low, and the spring rates set high, is this ok ?
boyRacer
18,569
Shouldnt you have more brake bios up front?
clarkey01
3,419
I like the car to drift more into the corners, but I'll try what you said
BCYL
7,803
Yeah you want the brake bio up front because the car is front-heavy...
you also want a higher spring rate up front compared to the rear to counter-act oversteering, and a stiffer sway bar in the rear...
