Little problem, if you havn't noticed by the title of the thread, my 7800GT is running at 83c LOAD!!! Now, there are a number of other things to consider. I have SLI setup so thats twice the heat. Now what I think the reason for such high temps is my X-fi is squezzed between the two 7800GT's since thats the last (and only) PCI slot left on the mobo. It looks very close to the VF-700 cooler and the backplate from the other VF-700 is bending a capacitor on my sound card (no biggy there, just had to install the card right and capacitor got out of the way, by bending some more...
Now, my case fans don't move squat and already ordered some new ones. These will be the new case fans: 2x70cfm at 29dba at 120mm. Also 2 90mm fans at 50ish cfm at 29dba. Sounds like good specs to me considering my stock fans run at 1400rpm, sure there quite, but they don't even move 20cfm (probably).
Now, will upgrading my fans help my gpu temp, and what else can I do for my GPU? to help lower the temps? Kind of want to OC the cards...
Thanks
Thanks
