GPU problem ? help please !
brandon888
here my system ...
VGA: SAPPHIRE VAPOR-X R9 280X 3GB GDDR5 OC
CPU: Intel Core i7-3930K
Cool: Arctic Cooling Freezer i30
MB: ASUS P9X79
RAM: Corsair Vengeance 8GB 1600 MHz
HDD: Seagate Barracuda 2TB 7200RPM Sata III
PSU: Corsair TX 850W
CASE: Cooler Master's Storm Enforcer
TV: Samsung 46 Inch (6400)
i have lag spikes evey 5 seconds while gaming .... and problem is on any game ..
let me describe what happens ...
Even if i stay and look a the wall and don't even move .... from 60 fps it drops fro 1 second to 22, 17 , or 30 fps .... it has one second lag ...
Temp of GPU is like 50-55C ... it't fine as i know on usage .. cpu is under 55 also .... tested HDD and memory . no error .... tested GPU WITH OCCT and furmark .. same here ..... what can be problem can anyone help me ?
maybe virus or something like that or gpu problem ?
Is AMD raptor running in the background? Try removing/disabling that, it may be causing issues.
I've a couple versions of it cause issues in some games; latest version seems fine. Are you running the latest drivers? Have you uninstalled old drivers and installed new or just installed over?
Sometimes older drivers can cause issues; using DDU can help with that.
Installed new beta driver but same problem ... seems like its systen lag because it even occours while cinematic ingame clip in far cry 4 or ACU
