GPU for Premiere Pro Mercury Engine?
-sandro-
Hello,
years ago Adobe started using GPU acceleration for their video editing software and only CUDA from NVidia was supported. Now they added OpenCL from AMD.
I want to buy a video card to help with rendering and timeline preview since it could really help.
Problem is AFAIK only low end/mid range Nvidia video card have been tested, as you can see here http://www.studio1productions.com/Articles/PremiereCS5.htm even a cheap GTX-550 Ti can almost be 8x faster than CPU only time line render. And twice as fast for exporting in H264. That's a big deal for under $100.
I only found these benchmarks that compare only high-end (really expensive!) cards http://www.pugetsystems.com/labs/articles/Adobe-Premiere-Pro-CC-Professional-GPU-Acceleration-502/ .
So how am I supposed to know if $100 and below AMD cards perform and they're even worth the trouble?
Should I base the decision using this http://www.tomshardware.com/reviews/gaming-graphics-card-review,3107-7.html and then considering Stream processing units like CUDA cores?
I'm looking for AMD because I remember they're usually cheaper, right?
You should be able to use the results from the low end and high end cards to extrapolate what a mid end card would likely be able to do. Are you trying to find the best bang for the buck or find just whats the fastest around?
I'm trying to understand how it works with AMD for opencl and if it could be related with cuda cores otherwise that comparison is useless.
There's really no relating of anything outside an individual architecture. That's why we have reviews.
If your budget is under $100, that doesn't leave you much. There are no 2GB 250X's below $100, there are no 650 Ti's, there are no 7770's, or 7790's. And the vanilla R7 250 and vanilla GTX 650 are comparable. So if OpenCL vs CUDA performance is a question, get the card that can do both.
Both brands don't do OpenCL equally as well. You would buy nVidia for CUDA and AMD for OpenCL.
THIS is the cheapest R7 265 I can find, $130AR. I wouldn't go with anything less than that for using OpenCL.
I would recommend though that the OP checks on forums where people actually use the app with GPU acceleration and see what works best.
