- Jul 14, 2000
- 56
- 0
- 66
My desktop machine went kaput (technical term) a while ago.. the symptom was the machine would simply freeze up after a while. After trying a few diagnostic and troubleshooting steps that didn't resolve the issue, I finally got around to opening up my box, and discovered two things:
1) On the bottom of my video card, a red LED was turned on (I had never noticed this before; it could have always been like that.. but I don't think so)
2) The GPU fan was not spinning
What are my troubleshooting/repair options?
The obvious answer is to replace the video card (a somewhat long-in-the-tooth by gamer standards Radeon HD 4890 http://www.powercolor.com/global/products_features.asp?id=133 that has been sufficient for my needs), but if there are other options, I'd like to consider them.
A couple of notes:
1) Had to earlier replace a dead power supply and monitor (can a monitor damage a GPU or vice versa? dunno..) on this machine.
2) I unplugged the desktop to move it for troubleshooting. When I plugged it in again, BIOS settings were lost (the machine is almost 4 years old.. do CMOS batteries die that quickly?)
A couple of notes:
