Hello All,
I am trying to decide on a GPU for my long term build. I have asked this question before when I narrowed my choice to the GTX 780 (and I thank everyone who helped me the first time), but now with the 290X, the 780 price drop, and the rumored 780 Rev 2 chip (GHz), I am now back to square one.
Here is the background: I only build a new computer every 4-5 years (due to funding reasons). My current GPU is two AMD Radeon 4890s in crossfire. I will be building a complete new build, and my choice is a 4770K for the CPU, and the Asus Maximus Hero for the MB.
I will want to get two GPUs in Crossfire/SLI, more for the longevity aspect. I felt that with my current build I was able to play the newer games this year with higher settings because I had the crossfire set up, and I want to continue with that. My current monitor is a 1980x1080, and if I did upgrade my monitor, I would either go 2560x1440 or 120Hz monitor (no 3D), both at 27in. I know that GPUs that I am looking at are overkill for the resolution I am at (or will be). Based on my experience, they would be overkill now, but as time goes on, and games get more intensive I would be covered the best I can. I know I cannot future proof my build, but I can at least mitigate the future requirements.
Here is my choices (SLI/Crossfire):
1) R9 290X non-reference (Asus Direct CU II most likely)
2) EVGA GTX 780 SC
3) GTX 780 (GHz), EVGA SC if it is available (if it is just a rumor, then not an option).
One of the questions that I have for the 290X vs. the GTX 780 is the vram. Does 4Gb make a huge difference vs. 3Gb? I know that games like Battlefield 3 state that the minimum requirements are 3Gb, and also games like Skyrim (which I play), can use a lot of vram if you utilize a lot of Mods (which I do), and I will most likely play any future Skyrim games as well. I also play games like BioShock, Fallout (with Mods), and different MMOs (not WoW).
In regards to the Power Supply, would a 1000w SeaSonic Platinum be enough?
I am planning to start my build in late December (Christmas).
Also, the GTX 780Ti, would not be an option due to the price. I am looking at a price of $550-$600 per GPU max.
I apologize for the length of the post, but I want to make sure I present all of the information.
Thank you all in advance!!
2) EVGA GTX 780 SC
