i was looking into getting a GPS system and was wondering if they had any additional fees. Do GPS units typically work out of the box or does it require an activation fee and monthly charge.
Usually with a mapping capable GPSr you only buy the map once, at least that's the way it is with my Magellan. I purchased the Magellan Canadian map and also the Magellan worldwide base map.
