Triforceofcourage
I want to get one installed in my 2005 Volvo S40 but I can't seem to find one that fits my car.
Any ideas?
Any ideas?
Originally posted by: jtvang125
Most indash nav units are double DIN (7" wide x 4.22" high) in design although there are a few that are single DIN (7"x2.11"). If your dash won't allow for a double DIN unit you may still be able to fit a single DIN. The problem with single DIN units is that the screen needs to fold out and fold back in every time you start and stop your car. On some cars the screen when folded out blocks other things on the dash (AC controls, AC vents..ect).
I'm not sure how your dash looks like but you can try consulting with crutchfield and see what they have. They have a pretty good database on what will fit into many cars and provide dash kits if available for your car.
Clearly you haven't seen a picture of the dash on his car. :laugh:
Text
Text
I was afraid that was going to be my answer. I guess I will just have to go with a nuvi. Thanks for your help.
Text
It looks like you could fit in a double din unit in there.
Text
Any ideas which double din unit I could fit and where I could pick it up?
Text
Text
Fit it in where? Did you notice that half the radio controls are in the center of the console below the screen up on top of the dash?
My wife's Lexus IS250 has this problem. The HVAC/stereo controls are all integrated into one big unit in the dash. Either you buy the car with NAV from the factory or you're screwed. We ended up buying a portable one for $350.
