GPS: Huawei S7 vs Galaxy S Vibrant (+ mini review)
Raduque
13,140
138
Warning: Long.
Bought the tablet the other day and one of the first things I did was test the GPS - ever since Samsung bit me, it's a standard test now. I don't take it for granted anymore.
The GPS on the Huawei tablet absolutely embarrasses the Galaxy S. It locks within about 3 seconds flat and if I zoom in close enough on Maps, I can see myself walk around the house. It has about a 5ft accuracy.
I'm running KA7 and done the hardware mod on my Vibrant, and I'm lucky to get a maybe-next-week lock time and around a 25ft accuracy. It loses satellite lock really easy and screws up tracking pretty badly, too.
I'm thinking the S7 is now gonna get schlepped around whenever I need something more accurate for location than "What city am I in?" GPS. Also, the 7" screen makes a great navigation display.
It's not a bad screen either, imo. Most won't like it, but after a bit of practice, I'm easily as good with it as I am with the ultra-accurate capacitive screen of my Vibrant or Droid.
Huawei's launcher and notification bar is surprisingly usable too. Only real problem there is no Portrait mode on the home screens, but there's 10 of them broken down into "Groups": Home, Web, Entertainment, Communications and Favorites. There's no notification bar unless you're in an app, the status icons are just there on the top right corner. You tap an exclamation point icon to drop the notify dropdown which includes a task manager. The S7 includes support for 720p playback of x264 or MPEG4 HD video >2.5Mbps.
It has a SIM slot and can be used for phone calls or mobile data, pulling EDGE on T-Mobile and should do 3G on ATT; there's no data connection status icon, just a signal strength indicator.
The display honestly could be better. It's not a BAD screen, it's just not very good at viewing angles. Brighter images work better than dark images, but it's got a fairly narrow top to bottom angle, if you tilt the top edge of the tablet away from you too far, the screen goes dark very quickly. Color reproduction appears fine to my untrained eye, and it's bright and clear when looked dead on, or off-angle to the side a little bit.
Hardware wise, the tablet has a Qualcomm Snapdragon 8250, same as the Nexus One, but clocked to 768mhz. There's apparently a way to overclock it to 1ghz but I haven't bothered, I find the tablet snappy in day-to-day usage. It has 512mb ram (OS sees 415mb of that), 175mb of app storage, and 8gb of built-in flash storage. It has 5 buttons on the front that you think are capacitive, but no, they're actual buttons underneath a flexible overlay: Home, Menu, Back on the left side, and Send/End on the right. There's also a trackpad/button but I haven't been able to get it to respond to my fingers other than clicking it. It also has two 2mp cameras (one front, one back) but they're pure junk, not even worth mentioning. The stereo speakers are loud and clear, but they're on each side of the tablet facing outward, rather than facing towards you, and they can get a little distorty at high volumes. It also has Bluetooth, WiFi, Accelerometer, Gravity sensor and ambient light sensor. Some say it has a notification icon, but I haven't seen it light up.
Overall, I think it's definitely a great device for $250 (I paid $228, OTD, after taxes and my holidays gift cards). It's no Galaxy Tab or iPad, but I think not having to lock down to a contract, or having to pay the Apple tax, plus the low price-point more than outweighs the bad of this tablet. It's highly usable, highly affordable, and highly recommended. The only real problem I have with it is the WiFi seems to lose connection when the tablet is asleep for more than an hour or so, to get it back you have to disable, then re-enable the wifi from the status icon, and the first notch of the kick stand is a little weak.
Pliablemoose
25,195
Poor screen
-800/420 resolution
-resistive screen
-poor viewing angle
Horrible camera
1.13 lbs vs Galaxy Tab 0.8 lbs (and the galaxy tab is heavy/chunky to me for a 7" device)
Can't charge by USB
Poor battery life
Android 2.1
I think it looks like hell too
Sorry, falls firmly into the craptablet category.
Raduque
13,140
138
Poor screen
-800/420 resolution
-resistive screen
-poor viewing angle
Horrible camera
Can't charge by USB
Poor battery life
Android 2.1
I think you're asking too much for $250.
No tablet charges via USB, not that I've seen. Battery life seems fine, but I haven't had it long enough to test (it's been off the charger for over half a day, and been used for over an hour straight and still has 70%+).
The weight is kind of heavy for what it is, but seriously, grow some muscles you weenie. Android 2.1 is fine, Hauwei has stated 2.2 will be sometime around march-april. Horrible camera yes, but as far as I'm concerned, it could have no cameras at all and I'd be fine... never going to use a camera on a tablet.
As for the screen, I have seen much much much worse than this. Viewing angles are fine from the side or top. The only time the viewing angle gets bad is if you tilt the tablet top away from you (bottom viewing angle?). The resistive screen is fine. Oh, and it's 800x480, but you're not limited to a 4x4 grid like other 800x480 devices are. The resolution is fine as this price point.
I think the nook color is ugly, and it requires too much work to make a usable tablet out of it. Plus, it can't make calls or use cellular data.
Edit: Oh yeah, Android Market w/no hacking required. Seems to run everything I've downloaded fine, too.
Pliablemoose
25,195
It looks like a 1960's transistor radio mated with an iPhone
I'm happy for you that you like it, but for me, after owning a couple of resistive screened devices, that alone would ruin it for me...
The other thing going for the nook color are the developers. They've hacked Honeycomb on it already (not very useable yet, but soon...)
http://www.youtube.com/watch?v=cKQHZTihjrU
kaerflog
1,899
4
I know its only $250 but I'd rather spend that $250 elsewhere.
Like add another $150 for the cheapest iPad.
Or I can get a used HD2 for $150.
It does everything better than this tablet except maybe reading books and I can put the HD2 in my pockets.
Raduque
13,140
138
The Hauwei fits in my pockets just fine.
I should have known better than to share my opinion and experience with ya'll.
And honestly, I don't really care about Cyanogenmod7. As I mentioned above about why I don't like the nook Color, I don't want to have to hack the hell out of a device just to make it usable. I had enough of that with my Galaxy S Vibrant. Thanks Samsung, you soured me on modding my devices! Now I only want them to Just Work out of the box, and the Huawei does. Maybe not as well as a $600 tablet, but well, it's not a $600 tablet.
An HD2 is too small to use as a tablet.
kaerflog
1,899
4
Well, you put the tablet up here for us to comment.
Did you expect us to only say positive things ??
We're telling you how we feel about this particular tablet.
I know its a stretch to compare a HD2 to a 7" tablet but like I mentioned, beside reading a book, what can this tablet do better ??
It has the same resolutions.
The HD2 is capacitive so its certainly is more accurate.
I'm just saying for $250, I'd rather get an HD2 and have $100 left over.
Or spend more and get an iPad or galaxy tab.
Pliablemoose
25,195
Or for the same $250 a nook color, the current darling tablet of the hackers.
It's not that difficult, and you have a great Android tablet when you're done.
As I said, I'm glad you're happy with it, use the crap out of it, enjoy :)
kaerflog
1,899
4
I never gave the NC a thought until you mention this.
Impressive for $250.
IPS display also.
I just figured out why the display on my MBA look so much better than my other laptops.
Raduque
13,140
138
No, I originally just wrote up a post stating how badly the Galaxy S gets curb stomped in the GPS department by the S7, but then I decided to expand into a mini review for ya'll to read my opinions on the tablet.
Nowhere did I post asking for questions or comments.
I certainly didn't expect "It's crap, NEXT."
It can do video playback better. 7" > 4" (or 4.3") for watching movies on, propped on a table or hand-held.
And honestly, I wouldn't spend more to get a Tab or iPad, because the only advantage they have over the S7 is, imo, the capcitive screen, and that's not worth an extra $350, especially when you're getting a carrier-branded device. If the Huawei S7 were capacitive and cost $500, I wouldn't have bought it or even considered it.
kaerflog
1,899
4
LOL, this is a public forum.
Don't post a thread if you don't want people to make comments.
shortylickens
80,287
17,082
A month ago I was begging for a fancy alarm clock radio with a big display and people kept suggesting I just go with a cheap tablet. This may very well fit the bill. All I'll use it for is time, weather, and maybe news. And if I can download an app that lets me custom adjust the brightness to a super low level, I'll even set it by my nightstand. I can download nature sounds for free to use as the alarm.
THANKS GUYS!
best.of
I have a Huawei S7, and it works just fine. Mine already has multitouch capacitive screen and its a great tablet, for the same price as the previous model . The only problem for now is just the lack of the flash player. I´m just hopping for the update to android 2.2.
To use internet, and multimedia apps dont need expensive tablets.
P.S. Sorry about my english.
