Gotta dive 18 feet in a pool to get a 20lb brick. Idea?
simms
8,211
Just hold your breath under and go go go? I can do 12ft and 20lb brick... and I can hold my breath for 82seconds while at rest.
Hopefully it's not too hard, but if anyone's a lifeguard.. any tips?
Cleaner
887
Was a lifeguard for about a decade its not too tough. Get a good deep breath and go. In the boy scouts we used to have a 25 lbs. rubber coated cannon ball we would use in the pool for the same reason. Now that was tough.
GasX
29,033
The only hard part if you have any leg strength will be equalizing your ears. 18ft is deep enough to potentially give you problems.
eelw
10,413
5,548
I would just dive down and tie a rope to the brick and drag it out from the surface.
tfinch2
22,114
18 ft is pretty deep, hopefully your ears don't pop and explode. :p I've done it before no problem with 12 ft.
batmang
3,020
oh no's.
J0hnny
2,366
Ugh, I hate it when it's deep. Going down is not that bad, but it's the up part. Make sure you get down with a hard dive and go straight at it to save time and air. When you grab it, push with all the leg strength you got, that should give you a good boost and your ascent should be easier.
silverpig
27,703
12
Farting on the way up helps too.
edit: it actually probably doesn't... air inside you = you more buoyant, but it's funny, so do it anyways.
MrScott81
1,891
isn't it better to go down more slowly to give your ears time to adjust to the change in pressure...If you can hold your breath for that long I would do down slow (saving energy too) and thus give your ears time to adjust....I know if I go down below 10 feet my ears bother me too much.
freebee
4,043
Had to do the same thing back in my swimming days. Except we had to carry it the length of the pool. Now that was the hard part.
thomsbrain
18,148
damn, that's deep! i know i couldn't do that right off the bat, that's for sure. kudos to you when you do it!
myusername
5,046
1. Inflate water wings to buoy 20lbs of weight.
2. Put on 40 lb. gold medallion
3. Jump into pool
4. Pick up brick.
5. Remove medallion
6. Charge little kids to see the sunken treasure
7. Profit!
GasX
29,033
going slow doesn't help equalizing as well as stopping doing a valsavla maneuver and continuiing down...
