Been popping in and out of the forums asking for video card advice, and I finally ended up replacing my 7870 with an XFX R9 290 for my three monitor setup.
The 7870 required me to have a powered mini displayport adapter, a displayport adapter, and a DVI to run all three.
The new card has two DVI plugs, one HDMI, one full size Displayport. I have no displayport cables or adapters, and only the center monitor (Asus) has an HDMI plug.
Hook the HDMI to the Asus, and use the DVI for the other two monitors. You know what happens next...all three monitors act like they are getting a signal, but only one monitor actually displays anything, and it aint the HDMI. I do a bit of reading, and buy an DVI to Displayport cable, hook that up with the other two monitors on DVI. Windows 7 64 detects all three monitors, but the Displayport monitor is shown with a tiny icon, no signal goes to the monitor. When I click detect, 1 and 2 show up, but the 3 does not show on the displayport monitor.
Hook the displayport cable to the other monitors and get the same result.
Figure this has been talked about here before but a search did not help. Can you?
System:
Computer
Model : GigaByte
Serial Number : To be fille***********
Chassis : GigaByte Desktop
Mainboard : GigaByte 990FXA-UD3
BIOS : AMI (OEM) FB 01/22/2013
Total Memory : 32GB DIMM DDR3
Processors
Processor : AMD FX(tm)-8350 Eight-Core Processor (4M 8T 4.22GHz, 2.21GHz IMC, 4x 2MB L2, 8MB L3)
Socket/Slot : AM2r2/AM3
Chipset
Memory Controller : AMD F15 (Orochi) CPU HT Hub 2x 2.61GHz (5.23GHz), 2x 16GB DIMM DDR3 1.34GHz 128-bit
Memory Module(s)
Memory Module : Corsair CMX16GX3M2A1333C9 8GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-33-10-5)
Video System
Monitor/Panel : (Standard monitor types) Generic Non-PnP Monitor
Monitor/Panel : Dell Computer DELL E2414H
(1920x1080, 24.0")
Monitor/Panel : ACI VW246
(1920x1080, 24.0")
Video Adapter : AMD Radeon R9 200 Series (40CU 2560SP SM5.0 980MHz, 4GB DDR5 5GHz 512-bit, PCIe 3.00 x16)
Graphics Processor
OpenCL GP Processor : AMD Radeon R9 200 Series (2560SP 40C 980MHz, 4GB DDR5 5GHz 512-bit)
Compute Shader Processor : AMD Radeon R9 200 Series (2560SP 40C 980MHz, 4GB DDR5 5GHz 512-bit)
Storage Devices
Seagate ST3000DM001-9YN166 (3TB, SATA600, 3.5", 7200rpm) : 3TB (F
HGST HDN724030ALE640 (3TB, SATA600, 3.5", 7200rpm) : 3TB (K
SanDisk SDSSDHII480G (480.1GB, SATA600, 2.5", SSD) : 447GB (C
ATAPI iHAS124 A (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (E
Logical Storage Devices
Hard Disk (F
: 3TB (NTFS) @ Seagate ST3000DM001-9YN166 (3TB, SATA600, 3.5", 7200rpm)
System Reserved : 376MB (NTFS)
Hard Disk (C
: 447GB (NTFS) @ SanDisk SDSSDHII480G (480.1GB, SATA600, 2.5", SSD)
New Volume (K
: 3TB (NTFS) @ HGST HDN724030ALE640 (3TB, SATA600, 3.5", 7200rpm)
Optical Drive (E
: N/A @ ATAPI iHAS124 A (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : ATI (AMD) IXP SB600/700/800 SMBUS Controller
LPC Hub Controller 2 : ATI (AMD) SB700/800 LPC host controller
LPC Legacy Controller 1 : ITE IT8728F
Audio Device : Gigabyte IXP SB600 High Definition Audio Controller
Audio Codec : Realtek Semi High Definition Audio
Audio Device : Pine Technology High Definition Audio Controller
Audio Codec : ATI (AMD) HDMI Audio
Serial Port(s) : 1
Disk Controller : Gigabyte SB700/800 SATA Controller [AHCI mode]
Disk Controller : Gigabyte SB700/800 IDE
Disk Controller : Gigabyte 91xx SATA 6G Controller
USB Controller 1 : Gigabyte SB700/800 USB OHCI0 Controller
USB Controller 2 : Gigabyte SB700/800 USB EHCI Controller
USB Controller 3 : Gigabyte SB700/800 USB OHCI0 Controller
USB Controller 4 : Gigabyte SB700/800 USB EHCI Controller
USB Controller 5 : Gigabyte SB700/800 USB OHCI2 Controller
USB Controller 6 : Gigabyte SB700/800 USB OHCI0 Controller
USB Controller 7 : Gigabyte SB700/800 USB EHCI Controller
USB Controller 8 : Gigabyte Etron USB 3.0 Extensible Host Controller
FireWire/1394 Controller 1 : Gigabyte VIA VT6308 1394 OHCI Controller
SMBus/i2c Controller 1 : ATI SB800 SMBus
Printers and Faxes
Printer : EPSON WF-3640 Series (600x600, Colour)
Printer : SnagIt 9 Printer (600x600, Colour)
Printer : Send to Microsoft OneNote 15 Driver (1200x1200, Colour)
Printer : Microsoft XPS Document Writer (600x600, Colour)
Fax : Microsoft Shared Fax Driver (200x200)
Fax : EPSON PC-FAX driver (203x203)
Network Services
Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 1Gbps)
Network Adapter : TAP-Windows Adapter V9 (Ethernet, 100Mbps)
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1)
Platform Compliance : x64
System:
Computer
Model : GigaByte
Processors
Chipset
Memory Module(s)
Video System
(1920x1080, 24.0")
(1920x1080, 24.0")
Graphics Processor
Storage Devices
Hard Disk (F
Hard Disk (C
New Volume (K
Optical Drive (E
Peripherals
Serial Port(s) : 1
Printers and Faxes
Network Services
Operating System
