Got my GTX 670 with a little positive surprise and now a REALLY negative
Discussion in 'Video Cards and Graphics' started by biostud, Nov 7, 2012.
  1. biostud
    biostud Lifer
    Feb 27, 2003
    14,963
    156
    it runs @ 32C in windows and that's where it's artifacting.
  2. Alusan
    Alusan Member
    Mar 5, 2010
    33
    Do you have ASUS GPU Tweak installed? I seem to remember that causing some red screen issues. You could try uninstalling it if you do.
  3. biostud
    biostud Lifer
    Feb 27, 2003
    14,963
    156
    I uninstalled, it but that didn't fix the problem. Will try other drivers now.
  4. Rvenger
    Rvenger Elite Member <br> Super Moderator <br> Video Cards
    Apr 6, 2004
    6,293
    4
    Biostud, Looks like your card is no longer maintaining a stable base clock. Flash it to the stock non top bios and use Nvflash for DOS. Download the HP format utility and put the Windows 98 boot disk on a flash drive along with NV flash.
    Disable write protection through nvflash then type nvflash -4 -5 -6 "rom file name"
    Try this file - http://www.techpowerup.com/vgabios/126187/Asus.GTX670.2048.120706.html
    #29 Rvenger, Nov 12, 2012
  5. KompuKare
    KompuKare Senior member
    Jul 28, 2009
    557
    60
    Your fourth picture down looks more a memory error. Strangely only in some windows, and while I would have thought that the frame buffer would be in continuous memory I guess it is possible that the driver would keep parts in separate locations and then combine them? Certainly the TV feed overlay looks like it's not affected in any of those shoots.
    If it is RAM, I know OCCT has an error checking option but I'm not sure if it would work for this.
  6. biostud
    biostud Lifer
    Feb 27, 2003
    14,963
    156
    I'm not going to do something that voids my warranty to get a possible dead card working.
    I can't even boot into safe mode without artifacts. When starting windows I get artifacts as soon as I start resulting in a hanging system.
  7. biostud
    biostud Lifer
    Feb 27, 2003
    14,963
    156
  8. Denithor
    Denithor Diamond Member
    Apr 11, 2004
    6,278
    16
    Um. So what was it?
  9. biostud
    biostud Lifer
    Feb 27, 2003
    14,963
    156
    I just misread something.
  10. Phynaz
    Phynaz Diamond Member
    Mar 13, 2006
    9,384
    261
    Why in the world would he do this for a card that is still under warranty?
    All he needs to do is RMA the card.
  11. Rvenger
    Apr 6, 2004
    6,293
    4
    I agree that RMAing would be the best option. I didn't think flashing to an underclocked bios would void the warranty when you can just flash it back to its original bios.
  12. bononos
    bononos Diamond Member
    Aug 21, 2011
    3,375
    29
    But it might be a good idea to see if something got knocked loose during installation. Or looking over the card and see if a component is barely hanging on due to solder cracks due to inadvertent rough handling.
  13. Jacky60
    Jacky60 Golden Member
    Jan 3, 2010
    1,123
    I'd be very annoyed and would RMA it ASAP. Forget farting about with flashing bios etc that's not a sensible route to take right now.
  14. biostud
    biostud Lifer
    Feb 27, 2003
    14,963
    156
    So I've started my RMA proces. I might be able to choose a 4Gb 670 instead of the 670 TOP, as the price is nearly the same.
    What would you choose +2Gb or +157Mhz?
  15. Ketchup
    Ketchup Elite Member
    Sep 1, 2002
    13,317
    MHz
  16. SpeedTester
    SpeedTester Senior member
    Mar 18, 2001
    995
    how do you RMA and get a different card? They gave you options, or you are returning to the vendor?
  17. Insomniator
    Insomniator Diamond Member
    Oct 23, 2002
    6,005
    69
    The mhz are meaningless. The memory could be super helpful if he ever SLI's or if games ever use more than 2GB (which is soon i'm sure).
  18. biostud
    biostud Lifer
    Feb 27, 2003
    14,963
    156
    They gave me an option of exchanging to another similar product.
    I'm never going to SLI the card.
  19. biostud
    biostud Lifer
    Feb 27, 2003
    14,963
    156
    So I've just picked up an ASUS GTX 670 4GB instead of the faulty TOP. Installation went fine without any hiccups so lets hope it stays that way. I think I'll wait a bit with over clocking. :) YAY!
  20. Qbah
    Qbah Diamond Member
    Oct 18, 2005
    3,706
    4
    You got the same card as me then :) Skyrim hits 3GB for me when stuffed with mods. I think you did well going for 4GB instead of the TOP model (I got the 2GB model first but then exchanged it for a 4GB model at the shop, since I needed more - kinda similar :p).
    Card is awesome! So quiet even when gaming!! :D Good you manged to get a replacement!
  21. Zxian
    Zxian Senior member
    May 26, 2011
    579
    Glad to hear you got things sorted out. Hardware failures are never any fun.
  22. biostud
    biostud Lifer
    Feb 27, 2003
    14,963
    156
    So I couldn't wait with the over clocking. Used EVGA precision to o/c and monitor speeds. I can run GPU offset +160, memory offset +300, power target 122%, temperature hits @ 65C with fan speed 55%
    Heaven ran @ 1440p, 4xAA everything else on max
    3DMark11 Performance graphic score default speeds (actual clock ~1019): 7925
    3DMark11 Performance graphic score O/C (actual clock~ 1254): 9503 (+19,9%)
    Heaven graphic score default speeds (actual clock~ 928): 828
    Heaven graphic score O/C speeds (actual clock~ 1137): 991 (+19,6%)
    So around 20% extra speed, seems ok to me :)
