got my 1.8A and P4PE running.
Stallion
3,657
After some trouble trying to format my drive so I could swap out mobos and chips I finally got it running.. So far I have had it to 2.6ghz (145fsb) and with it at 2.6 and my GF4 Ti4000 at 300/600 I got 12663 on the 3d marks. I guess I should do some adjusting with my xms 3200. There were 3 speeds available in my bios for my ram, do I just pick the highest one. When I was at 145fsb the highest was 355 I think.
Woot Woot!
ChampionAtTufshop
2,667
yeah that would work
although its still not up to par with ram potential speed
try for a higher overclock?
also make sure pci/agp bus is locked
check again, im sure there must be higher ones available....
my friend has same mobo with 1.6a and hes at 2.6ghz with ram at i think close 350ish...his geil is not working as he expected haha
Ketchup
14,559
248
Select the higher RAM speed you can, and then go into Advanced Chipset Features and set all your memory settings. (they should read 2-6-2-2 horizontally.) If there are preset configurations, you can also use those (Such as Turbo or Optimal). If you can get your FSB to 150, you should see DDR 400 as an option, which is a nice round number.
caboob
2,214
uhh champ, i don't think so.
at 133 FSB you can only get DDR355MHz (3:4). you have to get to 150 FSB to get DDR400. at least that's all that's selectable for me with my 2.66B on it.
Duvie
16,215
I think he is thinking about the Via P4PB chipset which is a p4x400 chipset.....It offers a 4:6 ratio at 133fsb.....Am I right???
ChampionAtTufshop
2,667
yeah lol my bad
thats what you get for waking up early when you shouldn't lol
Stallion
3,657
I had it to 145fsb but didn't notice any of the memory settings. But with it at 133 I have 355 as the highest available. I also don't see where it asks what ratio I want to set it to. My p4s333 had a option to set it to 1:1 ,3:4 and 4:5 I think but here I don't see it.
ChampionAtTufshop
2,667
this one doesnt have any ratios
its near the top, 3rd one down or something
it has ddr speeds available as numbers instead of ratios
unless you are asking about the ram timings?
Stallion
3,657
Nope, you answered my question. but since you mentioned it... My ram timing should be 2-6-2-2? Its corsair XMS 3200
THUGSROOK
11,847
your ram timings should be.... wherever they remain stable ;)
since your still playin with the cpu id suggest 2.5-3-3-7 for now and play with those settings after youve dialed in the cpu.
ChampionAtTufshop
2,667
if you go over 150 you probably will sacrifice onboard sound, so if you are using it i would say 150is max
then play around with the timings, you should be able to set them to the highest no problem i would think
run memtest86 to be 100% sure that ram isnt crapping out
Stallion
3,657
So what else should I test? So far 3dmarks is all I have done and I'm up to 13116 on that. :)
