got all the parts...now what?
WMartin
15
Got the case, mobo, processor, ram, and video card.
Now what do i do?
i keep hearing about testing, burning in the ram, etc......
YIKES!
Can anyone point me in the direction of a good tutorial?
TIA
WMartin
fredtam
5,694
Put it together and make sure it works first. RTFM before doing so. Install all drivers. Run memtest and Prime95 to make sure its stable. Good luck.
shootinyou
947
WMartin welcome to the forums :)
Take a look here, this should get you on your way.
Once built you can go here for testing and burnin utilities.
What parts did you buy??? and good luck on your build.
WMartin
15
mechBgon:
asus P4P800 delux
intel p4 2.8
entermax case 350 ps
2x512 pc3500
matrox 160 gig hd
ati 9800 pro
fredtm:
"RTFM before doing so" what's RTFM?
shootinyou
Thanks for the linkies
mechBgon
Oct 31, 1999
30,699
Originally posted by: WMartin
mechBgon:
asus P4P800 delux
intel p4 2.8
2x512 pc3500
matrox 160 gig hd
ati 9800 pro
fredtm:
shootinyou
Get your case unpacked and start by installing the motherboard studs into the holes that will match the holes in your motherboard. Knock out the case's I/O panel and put your Asus one in its place (this is the plate that the motherboard's ports peek out of).
RTFM = Read The Fantastic Manual :D and that's your next step. It shows how to install the CPU and its heatsink, the memory and the video and PCI cards. The guide linked above should help with that and the subsequent steps.
fredtam
5,694
mechBgon:
asus P4P800 delux
intel p4 2.8
2x512 pc3500
matrox 160 gig hd
ati 9800 pro
fredtm:
shootinyou
Read the manual. Most problems are cauaed by skipped steps by people assuming they know what they are doing. It is also a good idea to search through the forums for the different components you have to familiarize yourself with problems others have had so you will be prepared for them. Saves some time and headaches.
Mikesta
310
RTFM, They have a guide in there ;) thats the first place you go before you ask any quesionts :) then come here for extra help RTFM! :D
