- Oct 9, 1999
- 15,216
- 3
- 81
I was in the valley, driving west bound vanowen, saw cop going to take a left at a light.. went past him, saw him seconds later behind me at the next light, lights his cherry top.. i pull over.
Guy goes ' do you know you have blown headlight'.. i am like 'yeah it just blew, i noticed it a mile back'. Anyway guy gives me a 10$ fix it ticket.. ugh!
Anyway the bulb replacement isnt hard. the issue is this... I have a melted bulb connector.
I bought 2 replacement connectors, so i need to replace both connectors (both kinda melted).. funny thing is that i run stock wattage and yet they melt.
So question is how best to replace the new connectors so i can put a new bulb.
Should I solder the new connections and use a heat shrink tubing
Should I use crimp on connectors
Should I use T Splice connectors?
The big issue is that there is not much room to do work on that side where its blown, the radiator overflow tank and pipes are in that side..and i had replaced that connector once about 70000 miles ago, i used crimp on splice connectors and trust me that thing was hard to do in that limited space. So doing anything, even soldering will be hard.
CLIFFS:
Blown headlight - got a fix it ticket from LAPD
Connector on blown headlight melted. - have replacement connector tips
What best way to replace the said connector.
LOSS.. $10 for fixit ticket.
CLIFFS:
