Got a blue case? get a matching power supply.
I don't like how the second fan is one the back of the PSU and not on the bottom like the Enermax/Antec PSU's. Neat looking though I guess...
This is nice because I have 3 windows and it would look decent. Only problem is that clear fan protrudes and will block your 51/4 bay.
are those ADDA fans? im having a hard time identifying them... if so, then this power supply should be nice and quiet.
I have one, except mine is silver (320w) not blue. The fan does not block anything, but it doesn't draw air from directly above the cpu like the enermax one's do. Fans are yates loon's, and although this thing is supposed to be a 'silent' psu, it's noise is noticeable. You can get them and see specs HERE.
Yate Loons are the most generic of the generic fans. Stay away from them and replace them if you already have them in your case 😀
Um, does this mean I will have to get rounded IDE cables in a matching or complimentary color? Damn, turn you back and being a computer geek becomes all fashion sensitive.
Enermax makes a ps that's in a sort of a bluish anodized color. Not as blue as the RaidMax, but I think the specs are a lot better. Plus Enermax is a proven/trusted name. RaidMax is not. RaidMax isn't even on the AMD list.
With regard to the rear fan as opposed to a bottom one. Since the cpu fan is blowing cold air onto the cpu and assuming hot air comes off of it. With the PS fan being just above the cpu, wouldn't it make sense, that it is sucking hot air into the PS? With the RaidMax, it would seem that the rear fan is acting sort of like a top of the case blow hole and pulling air from the bottom of the case thru the PS out the back. The fan , if you have one, in the back of the case would take care of the hot air coming off the CPU and blow it out of the case w/o it going through the PS. Make any sense? 🙂
