Per the subject line, I should be receiving a 980Ti in the next few days and I figure, might as well keep one of my 680's as a dedicated PhysX card. Question is, do I need the SLI bridge?
Sound setup is pretty basic. Using onboard with a 2.1 speaker setup. I've been thinking about a set of nice headphones. What would you recommend?
I just picked up a set of Kingston Hyper X Cloud II headphones and they are GREAT!
http://www.newegg.com/Product/Produ...kingston_Hyper_X_Cloud-_-26-738-003-_-Product
I already have a set of $300 Monster headphones I can use, wasn't sure if there was anything in particular that made "gaming" headphones special though.
You should not correlate the price of Monster, especially Beats line, headphones with their quality. Most of that price is pure marketing and brand mark-up. The actual components inside are budget.
Here is my suggestion then. If you have an audiophile store in your state or happen to ever stumble into one, try out various headphones to see if this sort of thing matters to you.
Sell that GTX 680 (both - since according to your signature you now have two GTX 680 in SLI). Your new GTX 980 Ti will do fine by itself.
I also remembered I have a 650Ti in another box so I pulled both 680's from my box and i'm using the 650Ti as the dedicated PhysX card which works quite nicely. More then capable for PhysX, and it's quite a bit shorter than the 680 so the 980 is running cooler.
Pretty disappointed in NVidia with their SLI support. .... JC3 not supporting SLI/CF at all was the last straw for me.
There are almost no modern games that have PhysX while for older games like Mafia II or Borderlands 2, 650Ti should be more than enough. I'd sell those 680s while they still have some value.
I am surprised you decided to go for the 980Ti at this point since it's ~7 months old and the price on it hasn't fallen much. I thought for sure you'd wait it out until 16nm cards.
got my 980Ti today, so far so good. Playing Black Ops 3 maxed out @ 1440p smooth as silk.
I'm running a Dell S2716DG 144hz/1440p/gsync monitor. I'm definitely keeping one 680 for PhysX, particularly after what I saw here
