Google Wifi problem (wired connections have internet, wireless doesn't)
Spoooon
Very weird, things were great and working fine until they stopped. 🙂
Anything that's directly plugged in works. Right now, my desktop works fine, my phone does not. It will connect to the network and is stuck on obtaining an IP address. Same goes for my wife's phone. My wireless printer works fine.
Any ideas? I've reset, removed and added the pucks, unplugged stuff, moved things around, etc. Don't know what else to try.😵
On your phone, make it forget the saved WiFi SSID then toggle wifi off/on then reconnect. You'll have to enter the password again. There also is a way to block devices from Internet. Check to see if your devices are on it.
No dice. 🙁
