Google Launches Public DNS to Speed Up Web.
effowe
6,012
18
I'm currently using Level 3 DNS servers (4.2.2.1, 4.2.2.2).. wonder if this will speed it up. Will running a speedtest tell me, or will I just have to browse around to see if I can tell a difference?
SunnyD
Belgian Waffler
Jan 2, 2001
32,675
www.neftastic.com
traceroute or reverse IP lookups will be about the only thing that will change.
spidey07
65,469
Totally useless and it won't speed up anything, it could even slow your browsing down depending on latency. Just another way for google to collect stats on what sites you visit and possibly inserting content.
Do not want. If you want fast DNS then just run your own caching name server.
kranky
156
I don't know if it will affect speed or not, but I absolutely believe the above to be true.
SunnyD
Belgian Waffler
Jan 2, 2001
32,675
www.neftastic.com
Keep in mind, while Google runs its own backbone and has a very, VERY fast network, you'll be using servers likely 7 or more hops away from you to resolve DNS, as opposed to your ISPs DNS servers which should be no more than 2 hops away from you.
Kaido
Feb 14, 2004
51,574
7,243
Just swapped. Ping showed Google running about 2ms slower than OpenDNS for me, but the pages load up surprisingly quick. Google itself loads in a flash. Gmail is a bit speedier. Thanks!
spidey07
65,469
Those addresses are global load balancers, they'll redirect you to what ever DNS loadbalancer is closest. But still the point about these having higher latency/hops is very valid and why it could even slow down your browsing.
At 150 ms latency and probably an average of 15 DNS calls for a typical page you'd be adding 1.5 seconds of page load time higher than a typical 50 ms latency to your DNS.
SKORPI0
18,482
2,418
I have to assume this is a datamining initiative.
My thoughts exactly. Very time soon they'll know what types of sites we visit & how often. Hey maybe a Google ISP in the future too. Big Brother kind of... :sneaky:
spidey07
65,469
Why do you think they tried to by the wimax spectrum? So they could do exactly that.
Miramonti
28,653
100
Its bad enough that most sites I visit have google.com and googleapis.com etc. scripts in them. I'm really not interested in giving them a layup by using their dns servers.
SunnyD
Belgian Waffler
Jan 2, 2001
32,675
www.neftastic.com
To be honest, if they gave me fiber-class broadband without caps or restrictions at a fraction of the price of current ISPs, they can bend me over and datamine my ass for all I care.
spidey07
65,469
Thanks for the visual.
:eek:
FelixDeCat
31,014
2,683
I am interested in speeding up my internet browsing experience. Where do I enter this information?
Kalmah
3,692
In the DNS section of the TCP/IP settings.
Or, if you are using a router, you might need to log into that and set it there instead. Correct me if I'm wrong. I've been using opendns this way and it works.
