good webpage for matlab reference?
Darien
looking for one. i'm not familiar with the program at all, so i'm pretty much learning from scratch.
thanks
I usually use MATLAB's built-in help section. It has practically everything you need. If you don't have it, you should install it.
For more deeper explanation of some of MATLAB's functions, I goto the MathWorks technical support and look up some manual for whatever I need to do.
