Originally posted by: yllus
Bigfootcomputers.com
Originally posted by: simms
Think I should buy online? In general canadacomputers has good prices... thing is I don't know if they have quiet fans. And I don't know if I can exactly use a 60mm 13CFM fan on my CPU. Oh, my heatsink is an SK6.
I only didn't list them cause they are expensive.
although they have a good selection of case gear stuff... i've been to the storefront personally actually.
ordering online is no biggie, just know what you're buying. Why not use a fan funnel and put an 80mm fan on that heat sink? That would be much quieter. How quiet are you looking for? I bought a wack of Vantec Stealth 80mm fans a while back from NCIX when they were on sale, and they are rated at 20db and 27cfm, which should be fine. Lifetime warranty too.NCIX is who I recommend.
i buy most of my stuff from NCIX.com
use [anitec.ca] as a pricematch store.
I hadn't noticed that you wanted LED Fans, the Vantec Stealth's that I have are all solid black, but they were fairly cheap. NCIX has them on sale from time to time. A fan funnel basically converts 60mm to 80mm, so you can use a bigger fan. something like this
As to 120mm fans.. here are the 120's that NCIX carries. I notice they have a few 120mm LED fans, not sure how quiet they are though. I know my PSU has a 120mm blue LED fan. I like it, far quieter than 80mm's, or at least somewhat quieter.
not really. my PSU came w/ it, so that's why I have it. Changing the fan in your PSU will void its warranty as well. The standard PSU fan is an 80mm. What case are you using this stuff in? B/c if it has no window, there isn't much of a point.![]()
Don't use more fans than you need, is the easiest way to be quiet.
How many do you think I need? PSU, CPU... I guess you can do without in/outtake, but...
and how do I PM antiec.com on ncix?
what's the stats on your computer? is it overclocked? Realistically, an Athlon XP 2500 can run w/ just the PSU fan, another exhaust and the HSF.
Last question.. think I can use a vantec 80mm stealth with a fan adapter to cool the CPU?
