Good small, cheap 5.1 speaker system?
swbsam
2,122
Adjusting to life in an apartment with a wife who doesn't really care about surround sound. I'd like something as invisible as possible, with decent sound quality. My old subwoofer at 12" was way too huge, so I'll be buying the set from scratch.
Suggestions?
swbsam
2,122
Originally posted by: sdifox
budget? are you keeping the receiver?
Well, sub-$300 if possible. I've seen a polk 5.1 for $200 so that range would be ideal. Yep, I'm keeping my yamaha receiver
Polk set
Booty
977
I'd be interested in this too... we'll actually be moving in the next 6 months, but I wouldn't mind getting smaller speakers to "stage" our one-bedroom condo. The less clutter, the better it will show when it comes time to sell.
sdifox
99,355
17,547
sdifox
99,355
17,547
You should read yoyo's sticky, it has a few more mini systems.
Slick5150
8,760
The Energy Take 5.1 system is an outstanding value. Very small sats, but very strong sound.
Edit: might be a bit out of your pricerange now that I look back and see it.
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,204
45
Yeah, if you can keep your sub somehow (put a table over it or something?), then you'll be able to get better speakers on that budget. $300 for 5 decent speakers is already tight. Trying to get 5.1 on that budget is going to really limit your options.
(There are some small speaker alternatives to Bose mentioned in section 2.5 of the sticky thread)
swbsam
2,122
Originally posted by: justlnluck
I just purchased the Cambridge Soundworks HT305-SE. I will set it up today.
Awesome, let me know how that works out - it's often on sale.
krotchy
1,942
Originally posted by: swbsam
Originally posted by: YOyoYOhowsDAjello
Why did you even ask us?
Why didn't you guys read that I wanted to spend less than $300? ;)
We did. Mirage Nano's + your current sub = $250. You just didnt respond to it.
swbsam
2,122
Originally posted by: Oyeve
GL with those. Not bad for 199. My system would destroy em tho. :)
Thanks! I should have mentioned, the massive sub was just not going to work with my living situation, so I had to give it away.
The new set works great, but I'm well aware that I could do better. My new plan is to upgrade components (save for the sats, which I'll probably put together for a 7.1), piece by piece as I have the spare scrap.
Thanks guys, even though I didn't take your advice :)
sdifox
99,355
17,547
don't worry, the mob is assembling now, we are just short on pitch fork and torches.
Greg04
1,224
Polk set
Mirage Nano 5. Guaranteed to get the Overlord Seal of Approval. Keep your current sub though.
http://www.amazon.com/Mirage-S...&qid=1233715872&sr=8-3
250 is a great price for it.
This deal was so good that I bought 10 of them (2 sets), sold them on ebay, and made about $100.
I own them as my main setup with an OMNI CC center. Great bang for the buck and they look good enough for the wife.
