Good silent PWN fan for an NH-D14
Endymion FRS
69
I have an NH-D14, and want to replace the fans with silent-ish PWM ones. I'll be moving into an R4 later (from my current CM690 II). I was looking as an extensive but year old test done on OCN by a guy who tested several fans in various configurations on his NH-D14, and came to the conclusion that I should replace the 140mm fan with a Thermalright TY-140 and the 120mm one with an Arctic Cooling F12. I'm pretty sure the F12 is still a good fan, but has anything replaced the TY-140? Or are there any choices you guys would recommend?
bigpow
2,372
just replaced my stock LL fans with 3x 120 and 1x 140 Rosewill PWM fans. Cheap, work so far!
24601
1,683
40
86
TY-140 still best.
Things really only equal it, without being better than it.
Endymion FRS
69
TY-140 still best.
Awesome. From what I can tell on Thermalright's site, the TY-141 and TY-147 are the same fan in terms of performance? Except the 141 is 2 ball bearing instead of "Enhanced Hyper-Flow Bearing" of the 140 and 147, does that make a big difference?
24601
1,683
40
86
The TY-140 is a Fluid Dynamic Bearing, which is quieter.
