Elixer
- May 7, 2002
- 10,371
- 762
- 126
That mobo has
2 x PCIe 3.0 x16/x8
2 x PCIe 3.0 x8
2 x PCIe 2.0 x1
So, should work fine.
1) Is anything really excellent? I can just tell you that is the #1 card that people recommend on the FreeNas forums.
2) Right.
3) Yeah, correct.
4) Yeah, should be full speed, and is reliable according to most everyone on the FreeNas forums.
5) If your case airflow is good, then, no need. You could slap on a bigger heatsink as BonzaiDuck suggested, or stick a fan over the current heatsink.
Server parts have directed airflow, and I have no idea if your case supplies that.
I do recommend you check out other posts with this card on the FreeNAS forums (https://forums.freenas.org/) since you can never have enough opinions on this stuff.
There are just tons more users there that are looking to do the same thing as you.
2 x PCIe 3.0 x16/x8
2 x PCIe 3.0 x8
2 x PCIe 2.0 x1
2) Right.
3) Yeah, correct.
