- Jul 22, 2007
- 134
- 0
- 0
I'm putting together a system along these lines:
Phenom II x2 550
2GB Mushkin EM2-800
HD 4770 512mb
GA-MA780G-UD3H
It is going to be used to play Arma 2 and that is about all it will be used for. Essentially, this means that it will be fairly well loaded most of the time it is being used (100% GPU for sure, likely 80% or more CPU)
I'm trying to keep this thing as inexpensive as possible (read: value oriented, not cheap) and I don't want to compromise on the PSU. The Corsair 400w looks like it may be my best bet, because it leaves a little room to grow and I know it's good quality/will last a long time with this setup if nothing changes. Honestly, I know that this system will not be using much power, but I don't know if I should trust any of the lower-end solutions. I could probably get away with something like a Cooler Master 460 watt or something in that range ($50-60) but I don't know if that would be a very unsafe decision. I don't need it to handle any higher-end cards, I just need to know I have a good likelihood of having the computer last a couple years without a replacement.
Phenom II x2 550
2GB Mushkin EM2-800
HD 4770 512mb
GA-MA780G-UD3H
