good power supply
mervin338
Hi all! 🙂 I'm new to the forum but I'm a long time visitor.
I've been having some power supply issues and i've decided to get a new one. I've currently got an Antec 430 Watt power supply that is starting to flake out on me. I've been getting reboots every now and again and it does not seem to run well when my CPU is overclocked past 2.53ghz. My sytem starts to freeze and I my monitor flickers at time. Normally, system freezes are the result of heat issues, but my system temps are more than adequate. 29-31C at idle and maybe 42-44 at load. Though I have noticed that my PMW (power modulation) temps are significantly higher which I find strange. I've got a Arctic Cooling CPU fan that works great.
Anyway... I'm getting off the subject. 🙂 The boys over at the Abit Forum seem to think that Atec PSU's are junk. While I'm not expert on the specifics of power supplies I'm inclinded to listen to what those of you who are have to say on the subject matter.
I'm willing to spend around $100. I can go a tad higher if need be. It needs to be around 500 watts, with SLI compatibility and a dual 12v rail. Here are some of the ones I've been looking at.
We all know that OCZ, enermax and seasonic are great brands, but what about brands like coolmax and thermaltake?
http://www.newegg.com/Product/Product.asp?Item=N82E16817256001
http://www.newegg.com/Product/CustratingReview.asp?item=N82E16817159054
http://www.newegg.com/Product/CustratingReview.asp?item=N82E16817103512
http://www.newegg.com/Product/Product.asp?Item=N82E16817153029
http://www.newegg.com/Product/Product.asp?Item=N82E16817331001
[L=http://www.newegg.com/Product/Produc...82E16817341001]http://www.newegg.com/Product/Produc...82E16817341001
My system:
Abit AN8-SLI socket 939
AMD x2 4200 OC'd to 2.4ghz x 267 1:1
1 gig Gskill DDR500
Evga 7600GT
Antec SONATA II w/430 watt psu
Seagate 250 SATA
Seagate 80gig IDE
WD 40gig IDE
SoundBlaster XI-FI
2 DVD ROM's
