good power supply - worth geting?
avzay66
77
I plan on upgrading my computer a bit. Currently i have an Enlight 250W power supply in it. Is it really worth the money geting a bigger power supply. If yes...would a 350W be enough?
Gretzky
276
what are the upgrades? List your computer specs so we can make a better decision on what powersupply is needed.
Most of the times a 350watt psu is more then enough
Doh!
2,325
Can you share with us what your upgrade will involve? Which CPU, how many drives, other peripherals, gadgets, fans, etc. Your requirement will be directly dependent on the components you'll have in the system.
Generally, with recent hardware, 250W is on the lower side and may not provide enough juice for rock-solid stability. However, I have a system with a 1.33ghz Athlon/512MB/60GB/CDRW/CD-Rom/NIC/Radeon7500/SoundCard/other junk that has been very stable for the past couple years (using Enlight 250W). But all of other machines have 350W or higher PSU (all Antec or Enermax).
Anyways, whatever your system requires, I would never cheap out on a psu. So tell us what your system is going to be and we can provide better recommendations.
o1die
4,785
Enlight makes good power supplies, but I would definately upgrade. Newegg has an enlight dual fan 400 watt unit for $46 shipped, last time I checked. I found a single fan L&C 350 watt at dealsonic for $17.95 shipped. I bought it cause I found a review that gave me specs and said it was quiet, which is what I'm after. It runs very well, but I would still recommend a dual fan unit for cooling.
Dec 18, 2001
82
Actually, Fortron makes good, reliable PSUs. At least in my experience. I've been running two of them for about 3 years in Plll machines with nary a hitch. My other box is a P4 and I'm running a 400w Antec in that one.:D
Oakenfold
5,740
What exactly are you trying to run?
I run one hard drive, one cdrw,4200 and OC my beast to all get out(mad mad fans) with a measly 550w Antec.
It's overkill, but I like knowing it's there, you can't upgrade a power supply,
so you need to tell us your budget,. and what you are trying to run.
Coalfax
400
82
101
Um.. sure you can upgrade a Power Supply. Takes 4 screws and a small amount of patience ;)
Oakenfold
5,740
LOL!
I did'nt mean like that...sheesh u guys some times.
chizow
9,537
A good PSU can exorcise all the unseen bugs and specters haunting your system, causing unexplainable phenomena behind the scenes....
Pretty scary stuff huh??? ;)
Chiz
emjem
1,516
I've had good experiences with Enlights. Good 3.5 and 5 volt output. What you can do is upgrade your system and see if the 250w is enough before spending more. But once you decide to upgrade I would say don't fool with a 300+ -- get the Enlight 420 for $46 shipped at Newegg. Then you'll be good to go for a few more years.
