I've been told that 300W won't cut it for this powerhog with a normal amount of drives/PCI cards. Problem is, good 300W PSUs can be had for less than 20 bux, whereas 350-400W ones all seem to cost at least $50, with dual-fan AMD approved ones (like EnerMax) up in the $70 range. Since I just unloaded $205 on a Lian-Li PC-68+USB case, I am reluctant to fork out another $70 before even buying something with a single transistor (OK, maybe PSUs have transistors...what do I know). Perhaps someone can suggest a more affordable PSU that can handle AMD's beast. Or perhaps I should wait til August for an Athlon 4 chip, which presumably will use much less power? Any advice would be appreciated.
