Good match for a 1055t CPU and 1600 x 1200 max resolution
Caveman
2,539
35
Building a rig for the kids... Want best performance for subject specs but not overachieve so we save some $...
Recommendations?
mojothehut
354
Heya,
I'd say something along the lines of an Nvidia 650 ti
like this http://www.newegg.com/Product/Product.aspx?Item=N82E16814130841
Or an AMD 7850 for a little more money, like this
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202004
Both should be pretty good matches for the cpu you got going there. Personally I'd go with a 7850
However, if you really want to pinch pennies check this one out
http://www.newegg.com/Product/Produc...82E16814202011 7770 Ghz edition. $120ish
OOH just found this deal
The amd 6850. Will run a little warmer but give a little more performance than the 7770 if you're in the $120ish bracket
http://www.amazon.com/gp/product/B004DCOZTS?tag=at055-20
Caveman
2,539
35
Thanks much for those recommendations... I am a little surprised at the prices as I'd assumed something for $90-100 would get me there...
A little more wont hurt though...
raghu78
4,093
1,476
a X6 1055t is quite capable. with a bit of overclocking you can drive a HD 7870 Tahiti LE or HD 7950 boost. so whats your budget. also what psu do you have ?
Eureka
3,822
Well, the better question is, what do you want to play? If all the games are like League of Legends or Starcraft 2, a $100 650Ti will get you there.
Caveman
2,539
35
Budget is unlimited, but want to build this one on the cheap... Just want something that keeps up with 1055t at 1600 x 1200...
PSU is what's in my sig... That machine has been dormat for about 3 years...
A PC Power Cooling PSU is a *real* 510 watts... Should be enough or do I need more...?
lehtv
11,897
74
So, what games? How old are the kids?
7850 2gb is a safe bet, but with OC you'd get stable frames most of the time even with a 7950.
Exactly what is the PSU model? How many amps on the +12V?
Caveman
2,539
35
I'll assume worst case game at 1600 x 1200 - We'll be doing mostly flight sims which tax both CPU and GPU to the max - more than any FPS.
Turbo-Cool 510 SLI
When it comes to power supplies, it’s performance and reliability that count and nothing beats the heavy duty Turbo-Cool 510 SLI power supply from PC Power & Cooling. The first 510w PSU certified for NVIDIA SLI systems, the Turbo-Cool 510 SLI power supply is the industry’s undisputed 500W-600W champ.
  • 510W (650W peak) @ 50°C (industrial rated)
  • 2X more actual power than "500W" home PSUs
  • Heavy-duty caps, inductors, heat sinks, etc.
  • Premium sag and surge protection (.99 PFC)
  • +12VDC output @ 34A/38A peak (Single Rail)
  • Ultra-tight voltage regulation (+VDC@ 1%)
  • Super-clean output (+VDC ripple @ 0.5%)
  • New, quieter fan speed control circuit
  • 24-pin M/B and dual PCI-E connnectors
  • Industry's strongest warranty program (7 yrs)
RaistlinZ
7,470
9
^ Wow, Caveman you've really gotten a long life out of your system. I don't see many people rocking an Athlon 64 & 6800 Ultra these days. :)
mojothehut
354
I have my old AMD Thunderbird 1.2ghz downstairs, still running. Coupled with a Geforce3 Ti 500. 512mb DDR266 baby, win2k aww yea
Sometimes I sit down at it and play Unreal Tournament 1 :twisted:
