birthdaymonkey
Here's my system:
Lian-Li PC-V351
Seasonic M12II 620W PSU
Phenom II 940 @ 3.6 GHz (1.4v)
Gigabyte GA-785 GM
4 GB Kingston DDR2
GTX 460
Cooling:
Scythe Big Shuriken HSF with stock fan upgraded
Noctua 80 mm exhaust fan (1800rpm)
2 x Scythe Gentle Typhoon 120 mm intake fans (1150rpm)
I was running this system with no issues with an X2 555 BE @ 3.8GHz, but since dropping the quad core in, there is just too much heat in this little box to get a decent OC.
CPU core temps gradually creep up until the system becomes unstable under Prime95. Part of the problem might be the crappy TIM I'm stuck using while I await shipment of new stuff.
I'm thinking airflow might be an issue too, however, so I'm considering my options for adding some high RPM intake fans and putting them on a fan controller. (I guess the other option would be a better CPU cooler, but I'd have to get either a Corsair H50, which fits into this case with modding [I don't have any experience or tools], or go with the new Noctua CH14, which is ridiculously expensive for a cheap CPU like mine.)
I love the case so I want to keep it, but I need better cooling it seems. Can anyone recommend what they think I should do in this case? or which fans might help/work well? I'd want something that can put out high RPMs at full bore but be turned down and operate silently when I'm not pushing the system. Currently looking at either a Scythe or a Silverstone 3.5" drive bay fan controller and unsure of what fans would be best.
Thanks!
Lian-Li PC-V351
Gigabyte GA-785 GM
4 GB Kingston DDR2
GTX 460
Cooling:
Thanks!
