- Oct 30, 2004
- 11,442
- 32
- 91
I need to get off my arse and order the final components for my new rig. Here's what I propose to purchase for a Chieftec Matrix case and Opteron 148 (hoping to overclock to 2.8+ Ghz).
HSF: Arctic Cooling Freezer 64 Pro ($34 at SVC). I'm under the impression that it beats the XP-90 and would be on par with the Zalman 9500 and the XP/SI-120, and the price is right and it comes with Arctic MX-1 thermal paste.
Case fans (all 80mm, sadly):
I already own these three case fans that came to me bundled with an item I'd purchased off of eBay earlier: 2 Panaflo FBA08A12L = 24 CFM / 21 db (intake fans?) 1 Panaflo 1 x FBA08A12H = 39 CFM / 32 db (upper rear exhaust?). Are those 24 CFM fans too weak? Should I just order two more powerful fans?
For the other two fans (one exhaust and one side-intake) I'm thinking of purchasing two Logisys LT402UVB 35 CFM x 26 db fans ($1.99 each at SVC).
Would those be good enough or should I go with my original plan of getting two Panaflo FBA08A12U 80mm fans at 47 CFM x 38 db ($4.99 each at SVC)? They have the hydrowave bearings, so they should last longer, but I'm not sure I want two fans that do 38 db.
I would also end up with three intake fans (1 side, two front covered by case front panel) and only 2 rear exhaust fans, potentially creating positive pressure. Should I set it up so that the two most powerful fans are for the rear exhaust with weaker fans for the intakes?
