good air flow?
gRaps
can any1 tell me what exactly is good airflow.
what are sumthings to improve airflow? and how do the exhaust fans work?
basically can sum1 gimme a lesson on airflow 101 thanks
Airflow, in a nutshell, is the good transfer of air, from the front of your case, out the back of your case, with as much CFM passing at the end as possible.
Things that lessen airflow is overly restrictive fan grills, and a bad wiring job. Also, larger fans produce more air with less noise.
Exhaust fans work by sucking air out of the case and pushing it outside. This creates a vaccuum in the case, making more air enter from the front, creating a current of air, or airflow.
Intake fans work by sucking air in from the outiside and pushing it into her case. This causes overpressure, forcing air out the back of the case, thereby creating airflow as well.
The ideal situation is to create equal pressure while maintaining airflow. This is done by making sure the CFM entering the case is as close as possible to the CFM exiting the case.
Airflow can be improved by cleaning up your wiring job, getting faster fans, or buying a new case that uses larger, slower turning fans.
Thanks. What is CFM? and my case, Thermaltake Soprano, comes with 3 built in fans on the case. One at the rear, where the I/O shield is , and one at the front, where the button for power is, and one is on the side pannel. How can i tell which one is exhaust and intake fans?
Airflow, literally, is the flow of air around, into, or through an object. In the context of your question, airflow refers to the movement of the air into your case, inside your case, and finally out of it.
Airflow is important because air is a carrier of the heat energy dissipated by various components that make up your computer. Lots of things generate heat inside your PC: Your CPU, GPU(s), and motherboard chipsets are the obvious usual suspects. Heat is basically radiated from these hot bits and into the air inside your computer's case.
So how does airflow factor into the cooling of your computer? Well, there are basically two schools of air cooling thought here: Positive pressure and so-called negative pressure. Positive pressure means that there is more air pressure coming into the computer's case than there is exiting it. This is accomplished by having a larger volume of air entering your case than the volume of air exiting. How is this done? Have more fans actively pulling air into your case than pushing it out. Typically, this is by having powerful fans as intakes, and having no fans for exhaust.
Negative pressure, on the other hand, means having a greater volume of air leaving the case than entering it. You do this by having powerful fans actively sucking air out of your case, thereby exhausting the heated air. You may notice that this is the exact opposite of the positive pressure concept. To my knowledge, this method is more popular and more effective than a positive pressure case.
Airflow is also influenced greatly by temperature. As you know, hot air rises. Therefore, it would help your case's airflow if you took advantage of this physical fact. This is why you see most cases having their exhaust fans high and to the rear of the case; some cases even have "blowholes." This is also why most cases have intakes at the lower portion of the case's front. Cold air, after all, is heavier, and is therefore closer to the ground.
The air inside a conventional case, then, moves from low down in front of your case, gets heated by the various heat-producing parts inside, then rises towards the back and top. Knowing this, strategize accordingly how you would place your fans and at what speeds they'd run. For a negative pressure case, low speed/pressure fans go up front, and higher speed/pressure fans go to the back and higher up. Always strive for having more pressure leaving your case than entering it, in my opinion.
Lastly, how do you improve airflow? Air moves best when there's nothing in its path. This is why people take so much effort in managing their cables. Minimizing obstructions in the air stream is another key to good airflow. Cables and wires create aerodynamic drag, which interferes with the movement of air to the hot bits inside. Turbulent air is a poor dissipator of heat, as well.
Sorry for the rather lengthy post. I hope this helps, though.
CFM = Cubic Feet per Minute, a unit denoting the volume of air displaced or moved, as by a fan.
In most cases, the fans are arranged so that the following occurs:
Side, and front fans are intake fans
Top, rear, and power supply fans are exhaust fans
That usually generated the least impeded air current in most cases. Also remember that intake and exhaust fans are the exact same fans. you just flip them over to change between exhaust and intake. Hook a fan up to power and put a piece of paper on one side or the other. The side that pulls the paper in is intake, while the side that blows the paper is the exhaust.
I see, thanks
My next question is does any 1 have a 9500 Zalman HSF?
if you guys do or if you are fimiliar with the design, how should i position the FAN on the 9500 Zalman? The hsf is intake fan right? So which way should the fan face, the front or the rear?
Typical configuration for the Zalman is to install it so that the hsf fan is farthest away from the rear case fan. This will be exhausting air out the back of the hsf and into the rear case fan.
IMHO, 'good airflow' simply means evacuating 'hot' heat from a case -- in with the good, and out with the bad! To this end, exhaust fans are MUCH more important than intakes.
That's #1...
#2 involves directing this 'cool' air over 'hot' components -- primarily the CPU/RAM, chipset, caps, HDD, and video card GPU/RAM.
How you do this is up to you, but the #1 thing is removing 'hot' air from the case! If you DON'T do this, everything else is moot... 😉
Oops! I guess I should have kept reading...
Okay, forget Air Flow 101... on to the Zalman 9500!
Amazing! This thing draws n00bs like bees to flowers. I guess that's why they call them flower fans. Personally, I think they look like high-tech toilet bowl brushes, but that's just me... 🙂
Anyway, the important thing is to direct the 'hot' air toward the exhaust fan. This is dependent upon which way your CPU retention ring is pointed -- horizontally or vertically.
Okay, I'm tired of this topic... latez!
Well, i agree, i would get an ultra 120 or something "high performance" unless i was going for nothing but bling.
even at that, I almost agree on the toilet brush comment
