I figured that even with 6 TB, there will come a time, most likely late this year or early next year, that I will run out of space.
So, as to the OP, I'd go with the Red.
Personally I'd spend yet a few bucks more and get one of these: http://www.bhphotovideo.com/bnh/cont...=REG&A=details
Between the two, Red. Green should be off the table for your type of use. The Red also has a longer warranty.
I don't compress my rips. I tried but it takes too much time on my PC even on my i7-4930k. I already ripped 85 of my blu-rays and compressing all those would take a few days of non-stop encoding.
Does it sound like the 6 TB Green drive that I returned was defective?
I just returned a WD 6 TB Green drive. It was making ticking sounds every second during the HD Tune transfer rate test. My other hard drive don't make that sound during the transfer rate tests. I remember about 4 years ago I returned a WD 1 TB Black because it made those ticking sounds as well during the HD Tune transfer rate test and about 6 months later I rebought a WD 1 TB Black and that one didn't make ticking sounds every second in that test and it had a faster transfer rate as well. Does it sound like the 6 TB Green drive that I returned was defective?
Oh, you're using an enthusiast chip... that's your problem. Do you have a machine with a mainstream Intel CPU? Intel's QuickSync, which requires an Intel chip with an iGPU, can greatly speed up your encodes and the quality isn't that much different. I've encoded a full movie in around 15 minutes with it.
last i heard intel refused to open that up so the x264 guys could actually make decent use of it so they turned their backs to intel. they compared quicksync encodes with megui/x264 encodes done for speed instead of quality. basically, choose poor quality and you get same speed/quality as quicksync and the last time i tried it that seemed about right.
What about WD Purple: http://www.amazon.com/dp/B00IMPO5N8/..._t1_B00FJRS5OW
Any documentation for that?I know the AV drives did that, but I have not been able to find anything from WD differentiating the TLER implementation of any of the drives with it (gotta love how WD has stopped making decent datasheets...).Purple uses TLER=0 to reduce dropped frames, not good for data storage!
