Gonna try running a Firewire 800 SSD as my iMac boot drive
Eug
23,790
1,361
FW works as I have demonstrated but I wouldn't actually recommend it.
It's more of a solution for someone like me who already has an old iMac needing an upgrade. If you don't have an iMac yet then just buy a newer model. Minimum I would recommend is an iMac with Thunderbolt and USB 3.
Finding the right adapter might be tricky, https://support.apple.com/en-us/HT204592 but that'd be a neat way of keeping the computer useful.
Maybe this would do it: https://www.amazon.com/AllSmartLife-DisplayPort-Aluminium-resolution-ChromeBook/dp/B017TZTLC6 though by the timeline you're talking there will probably be more options.
Thanks for the info.
saigalmedia
saigalmedia.ca
I think you want to a purchase an SSD. Firewire 800 is just quicker than a normal hard drive, considering you approach the theoretical highest speeds.
